Re: IA,A,AV and B wheels
Posted by gene bender on December 11, 2006 at 17:56:58 from (67.55.226.214):
In Reply to: IA,A,AV and B wheels posted by Roger Mills on December 11, 2006 at 08:18:58:
AV is different as the rim sizes are larger that the rest of the series A,B,BN and C,SC and newer models. Two types clamp and the riveted bracket for adjustable tread spacing for mud or whatever type of spacing for the two front wheels Wts were avail and they weighed around 42lbs. The cast centers for rear around 145LBS with bolt on wts at around 145lbs. Dont know where you got the half wts thing all could be ordered with steel centers for rear or the heavy cast and of course wts front and rear. You can put an add-on wt on the inside of the steel center and another one or two on the outside. How much do you want? I have some of both fronts and rears name the set-up.
