Re: electronic issue with 404 tractor
Posted by Bob on December 23, 2006 at 15:45:46 from (69.178.229.154):
In Reply to: electronic issue with 404 tractor posted by eharmon on December 23, 2006 at 15:21:37:
GET THE CONTINUITY TESTER OUT OF THE HIGH-TENSION TOWER! If you DO get spark, the continuty tester will be "toast".
Using a 12-Volt test light on the PRIMARY coil terminal connected to the distributor, what does the light do while you crank the engine with the starter, key "ON"?
