Re: electronic issue with 404 tractor
Posted by rumplestiltskin on December 23, 2006 at 15:46:43 from (63.168.30.37):
In Reply to: electronic issue with 404 tractor posted by eharmon on December 23, 2006 at 15:21:37:
I'd be careful. If the coil turns out to be good, you'll be exposing your test equipment to tens of thousands of volts -- enough to fry just about anything electronic.
Can you beg or borrow an inductive timing light? That would just clip around the wire. Good light would mean good spark -- at least in that portion of the wire.
Mark W. in MI
