Re: H/ Rotella Oil?
Posted by John M on December 24, 2006 at 04:44:10 from (204.116.139.30):
In Reply to: H/ Rotella Oil? posted by Tom Windsor on December 23, 2006 at 20:45:39:
Theres only a couple of places where sludge would be now,the timing cover, governor,,lifetr cover,etc, places that you havent removed.What I do is get the non detergent and one quart of detergent, the non and 2, non and 3 so on and so on.I run them maybe 20 hours in between changes and only change the filter every other oil change.That way, the detergents can brake up the sludge little at a time.Ive done several tractors this way and have yet to have any problems.
