Re: 504 no start
Posted by Hugh MacKay on December 24, 2006 at 14:43:02 from (216.208.58.168):
In Reply to: 504 no start posted by Fire LT on December 24, 2006 at 14:11:07:
I doubt if your 504 is a 12 volt conversion, it may be an alternator conversion. By 1962 the first year the 504 was built, all IH tractors except 140 and maybe Cub were 12 volt. Even the 460 and 560 were 12 volt.
Is there power coming to your coil from the switch? Your best solution is use a test light, follow the wiring diagram in your manual to see where power has stopped.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
