504 no start
Posted by Fire LT on December 24, 2006 at 14:11:07 from (24.58.235.158):
I have a year unknown, 504 4 cyclinder gas with a 12 volt conversion that has no spark. there is power going to the coil but nothing coming out. I replaced the coil with no change. The only change that occurred is i installed a new battery. The next time I went to use it there was no spark. Any ideas?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
