Re: 504 no start
Posted by El Toro on December 25, 2006 at 05:25:59 from (205.188.116.133):
In Reply to: 504 no start posted by Fire LT on December 24, 2006 at 14:11:07:
You need to do as Hugh suggested on using a test lite or a volt meter to check to see if there's voltage at your switch in the on position. Make sure you have voltage going to the switch. This is usually fed voltage off the starter solenoid. If the engine cranks you must be getting voltage when in the start position. Check for a ballast resistor between the ignition switch and the coil. With the points open you should have voltage on both small terminals on the coil. No voltage present check for a broken wire or a bad connection at the switch or coil. Clean those points with some 320 wet or dry and make sure they are set at .020" gap. Then try to start the engine. Hal
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
