Farmall 706 engine swap
Posted by Curt Cooke on December 26, 2006 at 08:29:56 from (12.150.39.226):
What all is involved with taking an engine from a combine and putting it in a 706? Will I find that the crankshaft has to be bored for the trans drive shaft? What about engine mounts?
Help!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
