Re: Farmall 706 engine swap
Posted by the tractor vet on December 26, 2006 at 08:42:37 from (75.19.127.56):
In Reply to: Farmall 706 engine swap posted by Curt Cooke on December 26, 2006 at 08:29:56:
Well the ft timming cover will have to come off the replacement engine and the one off the tractor will have to go on and the rear engine plate off the tractor will have to be used along with the flywheel oil pan change and pick up tube manifold change maybe also i would use the dist. from the tractor as there maybe a timming change between a combine engine and a tractor engine if it is a gasser and if it is a diesel then change the pump .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
