Farmall H Mw pump
Posted by scott buckendahl on December 28, 2006 at 18:48:03 from (66.241.170.23):
I have a farmall h that had a m&w pump on it. I took the pump off and am wondering if the belly pump will still be working. There is a hole tapped into the bottom of the belly pump where a return line went in. The preesure line looks like it went up thru the plate behind belly pump. Also I tried putting a piece from another H between the timing cover and the dist. and the holes would not line up. Thanks for any help you can give me.
