Re: Farmall H Mw pump
Posted by chuck46 on December 28, 2006 at 19:20:33 from (64.136.27.229):
In Reply to: Farmall H Mw pump posted by scott buckendahl on December 28, 2006 at 18:48:03:
Hi, I think everyone that went to live hyd. gutted the belly pump, so I doubt yours will work again. The hole in the bottom was the drain. If the casting you have won't fit it would be because you have a late model H and are trying to put on an early model piece or vice-versa. They changed the timing gear cover and that casting about 50 or 51. You should be able to find one that fits. If you want hyd. at all I would sure keep the live system. Good luck, Chuck
