Re: plumbing a priority valve
Posted by Frank Packard on December 31, 2006 at 06:45:18 from (64.70.24.54):
In Reply to: Re: plumbing a priority valve posted by Allan In NE on December 30, 2006 at 16:13:34:
Thanks Allan Yes I meant that I was using the valve body to dump the excess from the valves. Just wanted to make sure I had all of the lines on correctly. Thanks, Poor Farmer
