Re: Brake Oil Seals
Posted by Paul G. in Mn on January 03, 2007 at 16:03:07 from (206.183.178.93):
In Reply to: Brake Oil Seals posted by David Goode on January 03, 2007 at 15:19:29:
you can replace the seal by removeing the brake drum, just take the nut loose and pull off. Then you will have to get ahold of the old seal and pull it out. then press in the new one. The sealing serface is on the brake drum so you will have a bit of room. Becarefull of the wooddruff key as it will be loose and you dont want to push that into the transmition when reinstalling the drum.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
