Re: Re: Inernational 444 Transmission Problem
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dale C on February 04, 2000 at 14:16:35 from (12.77.119.253):
In Reply to: Re: Inernational 444 Transmission Problem posted by 80 grit on February 04, 2000 at 10:03:44:
I have owned a 444 for 30 years. This has happend to it twice. The end of the shifter is whore a little letting it not come completly out of the last gear. Remove clip and spring to take out shifter then line up gear sliders for neutral.A new Shifter or build your old one up and grind smoth to fit slider slot will fix your problem. I was going to fix mine the last time it happend but never did and that was 8 years ago it now has 5625 hrs on it.
Post A Followup
: Re: Re: Re: Inernational 444 Transmission Problem
