Re: Super A - Steering Seal
Posted by banjo on January 09, 2007 at 20:50:38 from (65.67.203.22):
In Reply to: Re: Super A - Steering Seal posted by SuperA-Tx on January 09, 2007 at 16:16:47:
the shaft will slide out once you twist it past the worm gear. No hammer required. make sure the tires are straight when you remove the shaft so it will be even when you reinstall it.
