Re: Farmall M shutting down.
Posted by Brownie450 on January 11, 2007 at 05:58:28 from (207.177.82.194):
In Reply to: Farmall M shutting down. posted by dej(JED) on January 11, 2007 at 05:29:17:
Look in the fuel tank with a bright flashlight to see if there is a piece[es] of foreign material in the bottom of the tank which may be intermittently plugging the outlet. The neighbor had a problem similar to yours on his JD 95 combine. Turned out to be a wasp that was getting sucked into the tank outlet at random times. Probably the wasp was in the fuel nozzle & got flushed in with the fuel when filling.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
