B414 Won't Start
Posted by Paul(NS) on January 20, 2007 at 03:58:17 from (142.167.232.252):
This is a gas tractor. The tractors will not turn over, the solinoid just chatters then buzzes. How do I check to see if I have a defective solinoid or starter. the battery is old and in maintenence free. What should the battery read? With my Voltmeter should I get a reading at the cranking motor when I turn the key? It worked great(the tractor) until the other day.
Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
