Re: Recommended Rear Tire Pressure
Posted by Erik in WI on January 20, 2007 at 16:57:38 from (65.162.45.19):
In Reply to: Recommended Rear Tire Pressure posted by City-Boy McCoy on January 20, 2007 at 16:45:49:
NEVER put 35-40 psi in a tractor tire!
EVER! Even when trying to seat the bead! Who ever told you this is not right. The psi of the tire is the first numbers in the size. For example, 18.4 what evers get 18.4 psi, fluid or no fluid.
