Re: Recommended Rear Tire Pressure
Posted by Janicholson on January 20, 2007 at 17:25:23 from (66.173.50.90):
In Reply to: Re: Recommended Rear Tire Pressure posted by Erik in WI on January 20, 2007 at 16:57:38:
That would be ok for that one tire as a coincidence.
It is (no offense) bad policy.
Big tires with less load need less pressure small section tires with proportionally greater load need higher pressures. The key id the tire footprint in dirt. and is very different between bias ply, and radials. Goodyear Ag website has quantities of data on contact pach, traction, and ballasting driven ag tires. Please do not put in pressure depending on the tires size, it can be dangerous/wrong. JimN
