Re: Farmall A Carburetor
Posted by scotty on January 22, 2007 at 11:28:12 from (199.231.49.128):
In Reply to: Re: Farmall A Carburetor posted by old on January 22, 2007 at 09:38:25:
I have to agree with Old on this one. I had the same problem on my 42 A a couple months back and it ended up being a clogged main jet. Try what Old suggested and go from there.
scotty
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
