Re: Farmall A Carburetor
Posted by old on January 22, 2007 at 09:38:25 from (4.244.6.53):
In Reply to: Farmall A Carburetor posted by Brad in TX on January 22, 2007 at 09:11:47:
Sounds like you still have a clogged main jet. Is it one with the adjustable main jet or the type you can't adjust?? If its the type you can't adjust then heres some thing that might work. Pull off the jet cover plug and turn on the gas. You should get a good steady flow of gas if you don't then pull the drain plug turn off the gas and use spray carb cleaner in the main jet and spray it out good letting it flow out the drain. Some times that will open up the main jet enough for it to run well
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
