706D wiring for lights
Posted by GeneP on January 22, 2007 at 17:26:28 from (216.74.196.145):
My lights havent' worked for 3 or 4 years. The rear flasher was broken so I purchased an aftermarket yellow unit at the farm and home. It has two wires, the original had one. I also purchased a new light switch from IH and a new fuse holder. I think I can just use the old switch as a guide and probably figure it out. Is there a wiring diagram I can find on the web?
Our original manual burned along with our shop in 1977 so been winging it since then.
Thanks in advance, Gene
