Re: Farmall H Flywheel
Posted by Theman on January 31, 2007 at 10:49:05 from (65.248.77.5):
In Reply to: Farmall H Flywheel posted by Joshua Lawton on January 31, 2007 at 10:14:17:
The clutch housing narrows down too much at the starter to get the flywheel out that way. It will have to be split. When you get the flywheel out, check the back side of the ring ger teeth. They can be turned around and re-used if care was taken when they are removed - provided no teeth are completely broken off.
