Re: Gasket Question
Posted by Janicholson on January 31, 2007 at 15:06:27 from (66.173.50.131):
In Reply to: Gasket Question posted by SuperA-Tx on January 31, 2007 at 14:59:23:
It should be tight enough to just bulge out the gasket between the pan and block skirt. If you flattened the pan with hammer taps on a good fitting block where the bolts are, it should be ok. I like to coat some cork gaskets on the "oil" side with a film of #2 permatex prior to use. JimN
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
