Gasket Question
Posted by SuperA-Tx on January 31, 2007 at 14:59:23 from (4.227.108.108):
I ordered a new gasket for the oil pan for my SuperA from YT store and they sent a TISCO gasket. Appeared to be made out of cork? It fit fine but now even after tightening the nuts down a couple of times it seems like it "seeps" around/thru the gasket. It isnt enough to even be a drip but you can run your finger around the oil pan where the gasket is and there will be oil. There was no directions with the gasket so I didnt put any kind of sealer or anything. So do I need to just tighten the bolts down even more, take the gasket off and put some sealer on there, or get a new gasket and start over?
I need to replace some more gaskets so tell me what I did wrong before I do it again.
