Re: Gasket Question
Posted by Hobo,NC on January 31, 2007 at 19:11:47 from (71.29.34.192):
In Reply to: Gasket Question posted by SuperA-Tx on January 31, 2007 at 14:59:23:
if its neer the front it could be the timing cover gasket leak'in BTDT. Cork needs nuttin but a good flat surface to seal to. I do put a very thin coat of silicon on the timing cover gaskets on both sides and sum times no gasket at all just good automotive silicon. Back to the cork enny were their izz a joint you will need just a dab of silicon to seal the joint.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
