Re: Gasket Question
Posted by BOBM25 on February 01, 2007 at 09:08:00 from (69.68.42.16):
In Reply to: Gasket Question posted by SuperA-Tx on January 31, 2007 at 14:59:23:
Super A Tx, I put 3 different kinds of gaskets on my SMTA oil pan, all leaked. I tried gasket dressing on gasket, leaked. I tried grease on gasket, leaked. I tried permatex, leaked. I tried high temp permatex, leaked. Now I got this stuff that seems to work good. Its called "Right Stuff" from permatex. I think its pretty neat. It comes in an aerosol kinda can. You screw the nozzle on the end, then push it sideways, like a whip cream can. It seems thicker and more elastic than the permatex in the tube, plus its easy to lay a good bead down.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
