Re: H brake adjustment
Posted by kfox on February 01, 2007 at 14:25:01 from (63.18.166.53):
In Reply to: H brake adjustment posted by Guyzoo on February 01, 2007 at 09:50:39:
The shims effect the adjustment of the differential. They need to be replaced exactly as they were, and the gasket needs to be the same thickness. Take the old shims to a parts yard and see if they have any. I think they come in three different thickness. ken
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
