H brake adjustment
Posted by Guyzoo on February 01, 2007 at 09:50:39 from (207.179.164.77):
Hi, I just got my new brakes linings along with one brake pinion bearing and two seals. While removing the differential carrier(the piece that the bearing and one seals goes into, I broke two thin shims so can I just use a gasket to replace these shims?
My second question is: How do you set the brakes? especially the screw that is at the bottom of the brake cover?
THANK YOU VERY MUCH!!
