Re: Engine ID question
Posted by Chris from Wa on February 10, 2007 at 16:33:01 from (71.212.9.80):
In Reply to: Re: Engine ID question posted by Hugh MacKay on February 10, 2007 at 14:53:15:
third party image
The only numbers behind the oil filter besides the firing order is the part number 356318R2. By short I mean that the oil fill doesn't clear the hood. Neither does the exhaust pipe or the radiator cap. It has a double crankshaft pulley. Only one of them is used. A belt goes around the crank, fan, and water pump. The fan is also a double pulley. The second pulley on the fan drives the generator. I seem to remember that the A and C engines are shorter than the Super C. When I bought this Super C, the original engine came separately, as well as the original radiator and fan/water pump.
