my H was a little stuck
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by tony on February 07, 2000 at 15:13:56 from (156.144.109.24):
I went out Saturday morning to do a little work with my H and it was stuck! It just made a clunk when I hit the starter button. I pushed on the belt and tried turning it over using the fan blade trick but it was "stuck". I put a pipe and wrench on the hand crank shaft and eventually it turned loose. I couldn't believe it. I used it 5 days previous without any problems. Even in the colder weather (0 - 10) I never had any problems. I checked the oil (changed it about 15 hours ago) and it was fine. Does anyone have any ideas on what could have caused this. After it broke loose I started it up and it ran fine! I used it again today without any problems. I would like to do some more checking but don't know where I should be looking. Thanks
Post A Followup
: Re: my H was a little stuck
