Re: engine wont shut off after setting low idle
Posted by Hugh MacKay on February 11, 2007 at 08:26:06 from (209.226.247.49):
In Reply to: engine wont shut off after setting low idle posted by Emmy on February 10, 2007 at 21:18:35:
Emmy: I expect you have some wear at each pivot pin in the linkage. Do as Erik says or even just push the right direction on lever at pump. You could spend a $100. to make all those pivot point tight as new. You can also just simply shut her down from 800 rpm, from that point the linkage probably has enough momentum to shut pump down. Why are you idling that big engine at 400 rpm anyhow? Once you get below 600 to 800 shut her down, that low idling will take years off life of your engine.
