Re: Super A rebuild
Posted by Hugh MacKay on February 11, 2007 at 17:21:54 from (64.228.11.48):
In Reply to: Super A rebuild posted by Paul in IL on February 11, 2007 at 06:14:30:
Paul: You say smoking like a steam engine. What color is the smoke? If you remove the radiator cap after tractor is warm, do you see bubbles in the coolant?
If that smoke is white and you see bubbles, there is a good chance you have a head gasket leak. Right after the IH guy did the rebuild, did you run the tractor for a good working day then retorque the head?
