Re: still got wiggle room (I know, here we go aga
Posted by LA in Wi. on February 12, 2007 at 02:47:10 from (209.83.88.90):
In Reply to: Re: still got wiggle room (I know, here we go aga posted by Janicholson on February 11, 2007 at 10:35:28:
Janicholson, I like that strip of aluminum idea, will try that soon for a test. I feel that if I could move that worm gear closer to the sector it would be the solution. Maybe a good machinist could make me a larger dia. sector?
NoTools, I'll check out your idea, also.
I knew all the advice I'd get on this post was the first place I needed to go for a start. Thanks to all.
