Re: still got wiggle room (I know, here we go aga
Posted by Janicholson on February 12, 2007 at 07:46:36 from (199.17.6.122):
In Reply to: Re: still got wiggle room (I know, here we go aga posted by LA in Wi. on February 12, 2007 at 02:47:10:
Be careful that less worn areas of the sector (toward the ends left and right) might be tighter than the middle. Feel the looseness (without shims) at full left/right to see if the wear is uniform, or primarily in the middle. JimN
