Re: farmall m re-starting truble
Posted by Janicholson on June 24, 2007 at 22:33:00 from (71.87.39.51):
In Reply to: farmall m re-starting truble posted by james in mo on June 24, 2007 at 15:42:28:
I'm ging to add that a starter motor that is dragging (needs bushings) will draw down the voltage and keep it from starting. Also small car sized cables are a suspect. It needs 2-0 cables for reliable starting (it is a miricle cure at times) JimN
