Re: Farmall A - speed surging
Posted by Larry in Mo on June 28, 2007 at 07:47:27 from (75.105.155.251):
In Reply to: Farmall A - speed surging posted by Tom R. S. on June 28, 2007 at 07:01:21:
On the bottom of the governor housing there is a cap with a screw behind it. Turn that screw in a little at a time with engine not running, while making the adjustments. LE
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
