They're BOTH Right
Posted by A. Bohemian on June 28, 2007 at 08:08:00 from (207.170.88.55):
In Reply to: Re: Farmall A - speed surging posted by Larry in Mo on June 28, 2007 at 07:47:27:
Larry has given you the instructions to adjust "hunting" out of the governor. Hunting is where the governor doesn't like to settle down and run at a constant speed but instead "guns" the motor every second or so.
However, governors rarely start hunting unless there is another problem. As George suggests, read the manual and familiarize yourself with the governor adjustments and the renewal procedure, especially if the problem has cropped up SUDDENLY. I suspect someday soon you'll be glad you did.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
