Re: Farmall M governor question
Posted by HENRY E NC on June 28, 2007 at 15:57:45 from (216.119.6.12):
In Reply to: Farmall M governor question posted by aes on June 28, 2007 at 09:17:54:
Just finished replacing my gov and there is a lot to learn. First, check all the linkage on top of the tractor where the throttle is connected to the gov rod that pushes down on the cgov lever, Thosse springs up above cna wear etc. and throw the throttling out of kilter. Took me a while to adjust all that linkage. If the tractor is that old look to see if the weights in the gov are sloppy. Mine moved all over and the carrier needed replacin.
