Re: Farmall M governor question
Posted by Rootsy on June 29, 2007 at 05:17:09 from (24.176.33.123):
In Reply to: Farmall M governor question posted by aes on June 28, 2007 at 09:17:54:
On many of these tractors you will find that the link between the throttle and governor, under the hood is worn out and very sloppy which contributes to the excessive throttle movement before any action at the governor.
