Re: Any tool and die makers here?
Posted by Bob Kerr on July 03, 2007 at 08:32:10 from (64.12.117.8):
In Reply to: Re: Any tool and die makers here? posted by Rootsy on July 03, 2007 at 07:57:34:
The ring I pulled out of the parts tractor had the holes slightly egg shaped but not nearly as bad as the ones on my H. The bolts also had a wear grove around them. When I took one of the bolts and slid it into the hole but not where the grove was, it seemed to fit ok. I also noticed on the taper part of the bolt, it was copper plated, I suppose so it could be removed easier. How fast can you "whip some out"? hehehehe. If you want to give it a try, I could send you my bad ones for samples.
