Re: Could of bought a tractor!!!!!!
Posted by City-Boy McCoy on July 03, 2007 at 19:47:41 from (68.221.181.7):
In Reply to: Could of bought a tractor!!!!!! posted by jonnny2006 on July 03, 2007 at 19:02:12:
Johnnny: Try to get over it if you can. As they say, don't worry over things you cannot change; worry about the things you CAN change. In 1965, a semi-skilled entry level job paid $1.25 an hour. Gas was $.32 a gallon. Today, that same job pays about $12.50 and gas is $3.20 a gallon. The more things change, the more they stay the same.
