M Gear oil and such
Posted by Carden on July 05, 2007 at 19:50:27 from (74.33.235.201):
OK, changed the Diff oil as suggested and yes, there was condensation in there. Filled her up (13 gallons, $65 per 5 gallon pail) and have found I have a leaking axle seal. What"s coming out there is still milky so that can"t be good. Has anyone ever just pulled the cover of the end of the axl housing and used an RTV gasket seal to save removing the wheel? Does it sound like it would work? Here"s the big question though... How difficult is it to remove the top deck and can it be done by one man?
My father has a C he just did but this M deck makes that look like tin.
