Re: 2404 / 404 transmission cover leaking fluid
Posted by TxAllisMan on July 07, 2007 at 13:32:37 from (75.47.123.221):
In Reply to: 2404 / 404 transmission cover leaking fluid posted by MH on July 06, 2007 at 16:33:25:
HughB said: (quoted from post at 10:27:34 07/07/07) I will check the fluid level again. I may have it overfull. The level plug on the 2404 is on the left side in back of the axle. The plug looks like it has been in there a long time. There are no set screws above the PTO as that is where the 3 pt hitch is. Thanks for the tip on the gasket maker.
You are right about the location because its been so long since I have checked mine.
