2404 / 404 transmission cover leaking fluid
Posted by HughB on July 06, 2007 at 16:33:25 from (66.82.9.87):
My 2404 seeps a small amount of Hydraulic fluid from under the transmission cover while running. The
shop manual dos not mention any gasket used under the cover. The cover has the gear shift extending through it. I don't know if it ever had a gasket. I am wondering if I could use some kind of gasket maker to stop the leak? I doubt that it is overfull. The instructions are to fill it to the top. The plug to fill it is also on top of the cover. Any advice will be welcome.
