hydraulics 454 International gas tractor
Posted by Darwin Kurtz on July 08, 2007 at 06:57:14 from (138.210.244.77):
How full should the reservoir for the hydraulic fluid ( it is on the back of the tractor between the 3 pt)
The dipstick on the left side of the tractor down by your left foot is all worn off for some reason and you cant tell when it says full.
My main question.....is if the reservoir should be full of oil, Ive had people tell me oh no, that would be way too much.....so Im asking somebody here that knows.
Why would the reservoir be that big if they didnt want you to fill it.
Does anyone know how many gallons it should hold?
I think it was low on oil and added some and the 3 pt. came up and down a lot better after I did that....but its still not working perfectly and Im wondering if it just needs more oil
Thank you very much.
