Re: hydraulics 454 International gas tractor
Posted by John-Paul T on July 08, 2007 at 09:43:15 from (216.169.177.76):
In Reply to: hydraulics 454 International gas tractor posted by Darwin Kurtz on July 08, 2007 at 06:57:14:
dispstick you got it easy!
My 2500 you have to open a BIG plug on the top of tranny, fill to 7 1/2" of the top and then its right. Then check the rear reserves and fill them (at backhoe). Then run all the pistons full out for a few minutes, (fornt end loader too) then recheck all 3 spots. heh no dipstick luxery here.
Like mine you must find out how far from top it should be and if there are other areas the fluid is held in.
Draining mine today- 4 drain plugs under it, 2 at backhoe. Hopefully thats it! haha.
