Re: Engine not running properly
Posted by Janicholson on July 09, 2007 at 16:44:56 from (66.173.50.173):
In Reply to: Engine not running properly posted by Thane Johnson on July 09, 2007 at 16:24:54:
Two problems may exist:
The throttle shaft may be out of the tabs on the governor (on the other side from the last time allowing omly idle.
And the fuel supply may be plugged up. or restricted causing it to die. JimN
