TV---- OTHERS 756 PTO ADJ
Posted by lenray on July 11, 2007 at 16:22:34 from (66.129.43.61):
I had a leak around the shaft that puts the PTO in and out of gear down under the seat on the left side.
Took out that big nut with the seal in it and replaced the seal. Also got the adapter to plumb in the pressure gage.
Here is the question----is that nut on top--valve adjustment nut that hooks to the linkage the adjustment to use. I see where you mentioned about putting a nail into the controll valve stem.
Do you just turn that nut on top too get the desired pressure while holding the stem with the nail to keep it from turning?????
