Re: bull pinion slop
Posted by Harold Hubbard on July 17, 2007 at 04:04:33 from (66.6.176.23):
In Reply to: Re: bull pinion slop posted by Bob Kerr on July 16, 2007 at 20:18:50:
WARNING!!! DO NOT pull the bull pinion cage without removing the bull gear. The cage is slotted on the back side, and the bull gear goes into the slot to mesh with the bull pinion. If you just pull the cage, it will catch on the bull gear, and if you keep pulling on it after it catches it will break. Don't ask me how I know! Actually it was a C that I learned on, the hard way, but they are all similar. On an M you can remove the PTO and sneak in that way to unbolt the bull gear, then remove the axle, housing and all, but it still makes a tough job of replacing those bearings.
